white smoke?
white smoke?
Postby egferiolv » Wed Jan 14, 2009 1:43 am
Everytime i turn on the car, it sorta has trouble turning on. i have to step on the gas pedal and it will help it turn on. When i do that, lots of white smoke come out from the exhast. wondering if its bad or not. i have a 92 civic 1.5. and i recently changed the upper hoses, raditor, and the head gasket.
egferiolv
Poster
Postby ej2rey » Wed Jan 14, 2009 1:54 am
does it smoke at high rpms aswell? if it does then u need pistons rings.
if it only smoke at idle then valve seals.
BoRIcuA y QUE!
ej2rey
EG Groupie
EG Groupie
Postby teal_dx » Wed Jan 14, 2009 2:27 am
bluish smoke = oil burning = rings
white smoke = coolant = probably a leaking head gasket
Do Not PM me your technical questions. Post them in the forum! :thumb:
My 1992 SOHC Turbo Hatch
teal_dx
The Legend
The Legend
Postby Classiccarsrule85 » Wed Jan 14, 2009 2:33 am
teal_dx wrote:bluish smoke = oil burning = rings
^ what he said
now when you changed your head gasket did you get your head machined flat it might of been warped when you put it back on and thusly allowed the headgasket to fail
1980 volvo 242
2001 crv
Classiccarsrule85
powered by K series
powered by K series
Postby teal_dx » Wed Jan 14, 2009 3:20 am
or improper torquing of the head bolts could cause a leak
teal_dx
The Legend
The Legend
Postby egferiolv » Wed Jan 14, 2009 4:26 am
it only does the white smoke only on start up, and afterwards and runns fine.
And when the headgasket was changed, my cousin did it but all he did was put it on so i dont know.
egferiolv
Poster
Postby teal_dx » Wed Jan 14, 2009 2:31 pm
probably a very minor leak. after start up the engine heats up and expands, sealing up the leak. But I'd fix it before it gets worse.
teal_dx
The Legend
The Legend
Postby tolly » Thu Mar 26, 2009 2:31 pm
it might be petrol.........cuz as you said shes startin when you give her abit of gas so petrol might be pushed out the tail with out being burned not to sure what else it can be tho kid......
keep us posted on what happens :thumb:
tolly
Noobie
Postby Bcsavage » Thu Mar 26, 2009 2:44 pm
have a compression and leak-down test done, preferably after it's sat overnight to try and create the same conditions as when it hard-starts.
Bcsavage
Poster
Postby boosted94 » Thu Mar 26, 2009 5:32 pm
an excess of fuel will result from a black ish smoke. i recently had to re-do a head gasket for a guy who had had it done a week earlier, improper tourque and torquing sequence was the culprit. and you should always check your head with a straigh edge and feeler guage when you take it off.
Fuck rehab, boost is NOT an addiction, its a lifestyle.
Nah, who am i kidding I'm addicted.
boosted94
EG Regular
Return to Engine - General
Who is online
Users browsing this forum: No registered users and 5 guests
