- Wed Dec 03, 2008 2:55 am
#81643
for info only dont blame me if you mess up hurt youself or die
not real hard to do
tools basic
philips scredrver
10mm socket
12mm wrenches
time 30-60+ min **tools lift other factors cause time to vary **
be gentle on me this is my first teck write up
You want to start by removing you shift knob
You then want to remove you center console which consist of 4 screws
pull the e-brake section straight back toward the back seat then you can lift the shifter up
lift you cor so you can get underneith the car
you will need 12mm wrenches and a 10 mm socket
you will remove the bolt going through the tube of the shifter bottem
then you will need to remove the 10 mm nuts of the holding plate
they just spun on me
so i removed the arm assy it has a 12mm headed bold up by the tranny
pull and wiggle back and it will come out
i used a cut off wheel to remove spinning nut
with this out you can remove the rubber bushing
i had to cut part of it to fit over age has caue it not to strech as much
compare the shifter
i put bearing greese in the bushing to help lube
i installed new bolts
reverse to put together
the rubber boot at the shifter has a rim it streches around to seal to prevent air leak
not real hard to do
tools basic
philips scredrver
10mm socket
12mm wrenches
compare the shifter
... you had to cut those bolts off? .. dam.. all i did was unscrew... but yeah this was a good diy
