B16, B18, B20
By LowTEC-Derbo
#39458
a_CoUpE wrote:idk but i have seen personally a "poor mans R" run 14.9's consistently.
Stock GS-R block
B16 head w/ full Type R internals.
in a 93 hatch.
my buddy is running 13.6 in a stock b16a with cams in a hatch :) makes like 170whp.
By a_CoUpE
#39463
Stock GS-R block
in a 93 hatch.
yeah i told my friend he can get more out of that shit if he goes wit after market parts :thumb:
#39483 My LS with Si tranny was faster than 14.9s.
By a_CoUpE
#39621
Greasedmonkey wrote:My LS with Si tranny was faster than 14.9s.
Well damn. nice shit man. :thumb: how fast was it? :twisted:
#39774 it was arround a 14.0-14.3. That was until I spun some bearings...
Now its good if it starts up.
By snowboardgeek1
#40431 The bottom end of the GSR and ITR are quite different actually. The rods and pistons are not the same. ITR rods are stronger, built of a different material, and the pistons have a special coating that reduces heat.
The B16 head is the same casting as the ITR head. The difference again, is the internals, such as cams, springs and retainers. ITR heads are ported at the factory. The 96-97 heads were hand ported, while the 98+ heads were ported by computer-controlled machine work. All ITR motors were hand assembled at the factory under very tight tolerances.
I've talked to a few honda engineers, and they have stated, the ITR motors are practically the only motors Honda has developed that were primarily to be used on the track, but released for production use as well. They have stated that they took a GSR motor, and maximized it to its full potential without comprimising reliability.
As for a B16 head outflowing a GSR head, that's totally untrue. They flow either the same or a difference of 2 cfm's. Nothing to write home about.
In my opinion, a STOCK poor mans ITR can never be an ITR, not to insult your build Greased. I've driven a poor mans ITR setup and in no way does it feel as strong as a pure ITR motor. I'd compare it to a stock GSR motor with bolt on's. The power was approximately the same between the two that I've driven.
Greased, I'd highly recommend getting your head ported, either by Alaniz or Portflow. Alaniz will get the most power out of the porting, comparing street port vs. street port between the two companies. Problem is that Alaniz takes forever to get his porting done, but portflow's turnaround time is short.
A portflow street port, plus S2 stage II's with springs and retainers, and your setup will be just as fast as an ITR motor, or faster depending on the tune. Add a nice hytech replica header, my DIY ITR box, and a full 2.5" exhaust, and you'll definitely push 200whp. That setup I just pointed out, is a setup for reliability, which is what I'm all about. I don't like to build something that will blow up after 10-20 passes down the 1/4. For example, my setup on the ITR should last just as long as a stock motor, just because I didn't even touch the internals. I have basically a stock motor.
Good luck with whatever you decide.
By BurqueB16
#40444 great info! :thumb:
snowboardgeek1 wrote:The bottom end of the GSR and ITR are quite different actually. The rods and pistons are not the same. ITR rods are stronger, built of a different material, and the pistons have a special coating that reduces heat.
My setup doesnt have stock GSR internals. Ive got ITR rods and CTR pistons. Im hoping to be able to get head work done, but I dont think I can. time is creeping up on me.
By snowboardgeek1
#40523 Ahhhhh ok. Not bad. Should be a nice setup.
My neighbor with his poor mans ITR just dyno'd 182, with supposedly and ITR bottom end, B16 head ported by portflow, SMSP header, RSR exhaust, and an AEM 3" ITR CAI. He also has misc. stuff like HKS cam gears & a FPR.
I would have thought he'd dyno way more than 182 but Whitfield said he'd dyno at least 190 with my same exhaust.
#40544 I wont be able to get a portflow or what ever that other one is...but there is a shop out here that does good work that I have asked to do mine when the time comes. I really want to get it ported, but Im not sure that will be in the mix. That might have to come later.
By snowboardgeek1
#40622 Cams FTW! :) If you do get cams, make sure to get springs and retainers as well.
#40767 ive had cams since i got the head. Toda Spec Bs. Im looking for some good springs and retainers now.
By k0rean4life
#44670
Stock GS-R block
in a 93 hatch.
Most have been built WRONG. I had one in my full interior 93 SI and ran 13.7 with full interior only swapped the rack out with a CX one and removed A/C.
