By JUICE
#343105 That's why I've never even considered getting rid of my heat/blower. Gotta have it or come up with something cool like that if you're gonna drive on the street at all. Looks good man :thumb:
By SCKAPE
#343121 Cheers buddy! :)
There was few fail projects and took me awhile to come up with this.. But finlay is sort it! :)
And yep.. ill driver occasionally on the street, some meets, shows, i have to get on the track somehow, and i have nice, empty at night industrial estate not that far from home ;) Any way is still road legal so why not? :)
By Copepsy
#343132 what is this fore dehumidifier'' for the windscreen ? im having problems sometimes water is entering my car i think at windscreen.. ?
By SCKAPE
#343208 Finally sorted out all of my switches:
There was a few wires to play with ;)
By SCKAPE
#343293 There my new wheels - Sparco NS2 Crimson Racing 15'' - 5,5kg each.
Just after I bought them:
And now, after 2 weeks of my hard work on them...
:twisted: :twisted: :twisted:
By strigga
#343470 really nice project! i also had to choose - swap an other engine d16 or b16 or stay at the d13 and now i know that it was the right decision!
Best result NA was 122.9hp
By SCKAPE
#343799 I get new set of EBC discs and pads yellowstuff - I that will be as good as it looks like i will be more then happy :D
And few more thinks i replaced today:
lambda sensor, rotor, cap, VMS 10,2mm ignition leads and bit colder then standard irydium spark plugs..
By SCKAPE
#346471 I made some modifications at last time, here they are:
-Finished my DIY project - looong cold air intake pipe. The diameter inside is exactly what should be for my throttle, also internal surface is as smooth as possible and both bends has possible smooth and wide angles. Short photo story:
And there my final product:
- Get XTD clutch stage 3 for d16.
- Replaced bolt joints and bolts into stainless ones in my camber arms:
- Removed my gearbox and replaced bearings:
- Get STRONFLEX yellow engine mounts inserts - I have done some research... and as far I know that the stiffest polyurethane inserts on the market at the minute...
- New VMS adjustable cam pulley:
- New GATES RACING timing belt:
- Replaced my standard subframe and steering rack with DC2 type R one:
- New magnetic oil drain bolt, K&N oil filter, Lucas pure synthetic oil 5W-30:
- Few pics from progress:
- And some pics from Japfest:
By SCKAPE
#347233 Few new bits..
26mm front sway bar
22mm rear sway bar
asr...
By SCKAPE
#352256 Was missing for a long time... Long story short - F... brain dead woman cut my way on motorway on 30th of july last year and hit into front tire o my van... Crashed quite badly - head-one collision with barriers @ over 60mph and then rolling over few times... So I had a break with the project...
Any way I'm back!! Started again couple month ago. And there is what i have done so far:
Parts replaced/mounted in suspension:
- ASR
- Sway bars (26 and 22mm)
- STRONGLEX polyurethane bushes, bits for sway bars and inserts for engine mounts - all racing version - 90Ash
- HARDRACE toe control arms
- BUDDY CLUB - extended ball joints
- ARP extendet wheel studs
Also I bought lighter rims and tires:
- SSR Type X 15" - 4,8kg + TOYO T1R
- Weds sport TC05 15" - 4,6kg + TOYO R888
Also fixed:
- mugen look lip
- spoon look spoiler
- light weight fiberglass fenders
- new custom made (by TOP GEAR STOCKPORT) full exhaust system
Some pic:
And some videos from first test drives:
- 0-60mph
https://www.youtube.com/watch?v=UyinF1b0dP8
- sound o my new quiet exhaust
https://www.youtube.com/watch?v=Ny9Ghr2y0j0
There is more modifications in progress... :D
By TrailerTrash
#352258 love this car dude keep it up :thumb: :thumb: :thumb:
By SCKAPE
#352271 There is a bit more...
New battery, battery holder and wire:
My old set (14,7kg):
New set (7,3kg):
And all mounted:
