By kapow
#334299
#334519 How fast was that around the 5:20 mark? Car sounded good :thumb:
By bigJOE671
#336699 Made a video on this: http://www.youtube.com/watch?v=jiT-jzbzLIQ
So yesterday I finally bought a torque wrench. It was rated at 5-80 ft lbs. I needed one to do my cam seal for the longest time. Just had other priorities :(
Parts I needed to change
My cheat sheet
Removed Breather hose(red), valve cover nuts & washer/o-rings(yellow), and spark plug wires(green)
Removed all bolts circled in green
Took off oil rail and bolts
Found the culprit! Shank was almost flush with the surface. In the pic I unscrewed it a lil bit
Here's a reference of the messed up bolt and the new one
cam seal I was replacing
Oil's best friend (Hondabond)
Applied Hondabond to surfaces needed
Installed cam cap
Install oil rail and torque bolts 1-10 20ft lbs/240in lbs
Now torque bolts 11-14 7.1ft lbs/86in lbs. Since my torque wrench is on increments of 1ft lbs I did 7ft lbs.
I applied Hondabond to these corners to prevent future oil leaks
Installed valve cover with gasket
Now I finished installed the valve cover breather hose, spark plug wires, and I just hand tightened the valve cover nuts. Last time I tried to torque em they started to strip.
By bks84
#336793
By bigJOE671
#336950 During my time of fixing the cam seal leak...I found out my VTEC solenoid was also leaking oil. I was under the impression I also had a JDM B16A Obd-0 engine.
So when I went to research on how to change that gasket there was two different part numbers. B16A2 motors use different VTEC gaskets than the JDM B16A Obd-0. Attached a pic for reference.
B16A2 motors use
Upper: 36171-P08-005
Lower: 15825-P08-005
So moving on...I went to buy some gaskets
Upper gasket bolts
Lower gasket bolts...filthy in this area :(
Had to disconnect these two connectors
I took off the solenoid and inspected both gaskets. I seem to have a VTEC solenoid that uses B16A2 gaskets :x
So I ordered the gaskets that are on the right and Now I need to return them because I need the gaskets on the left :x
By brandoff88
#336961 someone could have swapped the vtec solenoid assembly...I have to change mine on my d15b vtec because I broke the green connector on it when putting my motor in lol
By bigJOE671
#337103 I went back to the dealership and bought some more gaskets and returned the ones that were not the right size
This receipt is the gaskets I bought for a B16A2. A ripoff if you ask me!
This receipt is the gaskets I bought for a JDM B16A OBD-0
By bigJOE671
#337309 Almost ready to cut and buff my paint
Pre-wash
Claying ready
Showing how its done!
Claying done
Taped off unwanted cut and buff areas
First time wet sanding
Wet sanded a lil more after this pic
First compound pass
These pics don't do justice! Looks better in person.
Results in video
http://www.youtube.com/watch?v=dWrb_-OB ... e=youtu.be
I still need to do a couple more passes. I found out I was not at the right speed (not fast enough).
This was my first time wet sanding and buffing paint. It was a learning process. But overall I'm glad with the results
