- Fri Oct 12, 2012 8:27 pm
#317825
im loking to get new hoses but idk what to get its in a 95 civic coupe do i get acura hoses or honda hoses
- Fri Oct 12, 2012 8:34 pm
#317826
What engine
- Fri Oct 12, 2012 8:39 pm
#317827
b18c1
- Fri Oct 12, 2012 9:02 pm
#317828
Integra hoses are made for a full radiator. If you have a full integra radiator then get integra hoses.
If you have a half size civic radiator, then you will want to get Delsol VTEC (DOHC VTEC b16) hoses.
- Fri Oct 12, 2012 9:14 pm
#317832
will the em1 si work also?
- Sat Oct 13, 2012 12:57 am
#317846
Edit
- Sat Oct 13, 2012 4:21 pm
#317884
HeikDiesel is completely wrong.
If you buy them for a Del Sol VTEC/00-01 Si the hoses will be too long and the wrong shape.
Buy them for the engine youre using. A Gsr's upper hose is on the front of the cylinder, like an LS a B16/ITR is on the back of the head under the distritbutor.
If youre using a D series radiator the hoses for a GSR will be too large and you'll have to sinch the clamps down to prevents leaks.
I suggest using a Del Sol VTEC or 99-00 Civic SI radiator since it will come ready for "B" series size hoses. I think they're 36mm whereas D series are like 32mm, or something.
In in the end, buy them for the engine you're running.
RWMIII wrote:A little piss ant like you isnt worth being banned over.
EG6b20R wrote:Yea he has a bad habit of being overly sarcastic.. .. at the wrong times..
- Sun Oct 14, 2012 3:29 pm
#317915
will the gsr houses fit my b series half size radiator ?
