- Sun Nov 27, 2011 7:22 am
#283110
lowering springs on factory struts??? will the difference of spring having any bad effects on the dampers?? if so what?
94_jdm_ferio wrote:Unless you buy progressive springs you will blow ur stock shocks... no and if or buts about it.. just save up and get a nice progressive spring like eibach, tein, neauspeed, skunk2 just make sure they are progressive spring rate springs
kingjmack wrote:I am one of the people who went the cheap route and put $30 ebay adjustable coils on my stock struts., They gave my the lowered look I was going after, but the ride is absolutely crap. If all roads were flat, I'd be good. The springs are waaaaaaaaaaaaayyyyyyyyyy too soft, so any type of bump or un-even surface I go over, it can get bouncy.
You will always hear people say to save up and buy good quality stuff, and that's what really needs to be done.
If you want the lowered look, but don't have alot of cash, I'd get name brand lowering springs on the stock struts before I'd buy ebay coils until I could save for a decent set-up, but you still run the risk of blowing the stock struts.
What is your budget for your spring/sturt set-up?
Abilliondollers_vtec wrote:kingjmack wrote:I am one of the people who went the cheap route and put $30 ebay adjustable coils on my stock struts., They gave my the lowered look I was going after, but the ride is absolutely crap. If all roads were flat, I'd be good. The springs are waaaaaaaaaaaaayyyyyyyyyy too soft, so any type of bump or un-even surface I go over, it can get bouncy.
ill prob do that, NO BUDGET but ill save up for whatever my car is going to "need"
Apexracing wrote:Lowering springs are bad for stock struts in general. Even progressive springs, stock struts or stock replacement struts. Are designed to ride at the stock ride height. When you reduce their travel thats when they tend to blow. They make aftermarket struts like the koni yellows that are designed for lowered cars.
94_jdm_ferio wrote:Apexracing wrote:Lowering springs are bad for stock struts in general. Even progressive springs, stock struts or stock replacement struts. Are designed to ride at the stock ride height. When you reduce their travel thats when they tend to blow. They make aftermarket struts like the koni yellows that are designed for lowered cars.
not always true
my friend has GC sleeves on stock shocks..
he's been riding like that for almost 3 years
and not 1 shock has blown...
unlike my sprint drop springs.. i blew the shocks in 2 weeks
TrailerTrash wrote:he had it slammed all the way down.. But he is now running a bigger wheel so he rasied it up94_jdm_ferio wrote:Apexracing wrote:Lowering springs are bad for stock struts in general. Even progressive springs, stock struts or stock replacement struts. Are designed to ride at the stock ride height. When you reduce their travel thats when they tend to blow. They make aftermarket struts like the koni yellows that are designed for lowered cars.
not always true
not to disagree with you or start anything but how low does he have the sleeves cranked down?
