- Fri Sep 16, 2011 1:44 am
#272256
sounds like you need to go get an alignment.
- Fri Sep 16, 2011 1:45 am
#272257
no it would be due to your toe being out of wack.
and 2 inches
mine was slightly over one inch off and it ate through brand new tires to the cords in 600 miles
and 2 inches
- Sat Oct 08, 2011 7:22 am
#276765
i took it to a place that has extremley good alignment setup and couldnt get it eqauled out .
sadly im running out of money, i been buying new tires every 3 months till i can figure out the problem (not burning out and driving crazy, other than fast on highways).
-when i turn right my car leans in to the left, my left turns are fine, but my right turns into a parking space always end up being really wide??
-Also when i turn my wheel all the way to the right , i can hear my tread slowly scrape to hell. and yes my cords always end up showing with in two months , mainly on the Left side of the Right tire. Then i slowly see the inside of the left tire do the same.
*if anyone has an opinion, plz help me out, i dont want to dislike civics *
- Sat Oct 08, 2011 12:51 pm
#276776
to your knowledge has the car been wrecked? maybe something is bent and has been missed by the alignment techs.
take it someplace else or this may sound a lil drastic but to a body shape and see if they can put it on a frame machine and see if the front end is jacked up, bent or something that would cause the problems youre having.
at the very least, jack the car up and look for yourself if anything appears bent. mainly control arms, steering knuckles, etc. maybe snap some pictures and post em up for us to see.
if the car has been wrecked and was either never fixed or fixed poorly, then thats no reason to hate Civics! lol
RWMIII wrote:A little piss ant like you isnt worth being banned over.
EG6b20R wrote:Yea he has a bad habit of being overly sarcastic.. .. at the wrong times..
- Sat Oct 08, 2011 10:25 pm
#276843
after buying the car from my (friend) i learned
-out ran 3 cops, 3 seperate times
-had 115 on steep mountain roads
and what concerns me the most
-was on two side wheels at an angle at one time.
i currently have 15'' rota slips on, should i get stock to add more weight to help with it?
- Sun Oct 09, 2011 1:16 am
#276851
thats not going to help anything. something is seriously wrong with your car.
jdmdx93 wrote:i currently have 15'' rota slips on, should i get stock to add more weight to help with it?
- Sun Oct 09, 2011 4:44 am
#276871
Take the car to a REAL mechanic that is KNOWN for being good at his job. You need someone with knowledge to look at your car.
Everyone here has told you many times that you have problems with TOE. Not many things will alter your toe, so you need to get those things checked out and while you are at it, everything else it seem.
1986 Nissan 300zx
1980 Kawasaki KZ650
2014 Kawasaki Ninja 300
1980 Kawasaki KZ650
- Mon Oct 10, 2011 12:17 am
#276962
i have a d16z6,
i took a look at my right axle and when i went to see if something was loose,
i pushed on that thing (PICTURE LINK BELOW) and it was loose, i could move it up or pull it down, im no expert but it seems like it has too much play
would this be a reason why? why my tires are messed up? and would it also cause a loud discrete hurling grinding sound?
- Mon Oct 10, 2011 8:10 am
#277024
That piece will have no effect to cause a growling sound. That sounds like a wheel bearing.
jdmdx93 wrote:i have a d16z6,
- Mon Oct 10, 2011 1:25 pm
#277032
You might have bent lower control arm(s) or a bent sub frame... it sounds like you bought a car that has been beat to hell and back.
Posting some pics could help us help you.
My 1992 SOHC Turbo Hatch
- Mon Oct 10, 2011 3:45 pm
#277053
It's the area of the body/chassis that control arms bolt to. A good curb smack can push the metal in because it's not really thick metal to begin with.
I'd take it to a shop that can check the frame for straightness.
