- Thu Nov 19, 2009 6:53 am
#157296
recently my right side fog light has gone, only the left side will lit when i turn on the fogs, but everytime i turn it off and turn it back on the right side flickers. I've checked for lose wiring but still same problem, i even tried switching the fog lamps but only one side will stay on and the other will just flicker and die out. could this be a blown fuse?
- Thu Nov 19, 2009 7:42 am
#157297
sound to b more of a grounding problem
- Thu Nov 19, 2009 2:52 pm
#157321
Like it was said before check your ground and make sure everything is wired properly...
If it still flickers then you need to if you havent add a relay for both lights... I install those in my shop all the time and in some cases like in chevys that happens to the headlights as well..
- Sun Nov 22, 2009 9:16 pm
#157862
check and switch the ballasts.... but first check all your wiring to the relay and switch inside the car,
it kinda sounds like the ballast could have took a shit since you changed the bulb and looked at the wiring
