- Thu Aug 13, 2009 12:10 pm
#137648
What eg do you have... ex/cx/dx/si/lx etc... and Are the wheels 4x100? or 4x114.3? most of them ive seen are 4x114.3..
- Thu Aug 13, 2009 12:38 pm
#137652
depends on ride height, tire size, camber, spring rate...
You should be okay unless any of the above are too extreme. Worst case you may have to roll the inner fender lip.
FREDDY1 wrote:hey all i found some wheels for a good price.
enkei apacheV's 14x6 +18 can i use this wheels on my eg with out any problems??
My 1992 SOHC Turbo Hatch
- Thu Aug 13, 2009 12:44 pm
#137653
I almost got some that were the same style this past weekend for a Flippin good deal but they were 4x114....Also Teal is right thats a very low offset...But if u can pull it off then SICKNESS!!
(Here are the ones I was gonna get)
- Thu Aug 13, 2009 4:05 pm
#137704
those are 4x114.3 pattern. 4x100 has the holes closer together.
the wheel would also stick out 27mm more than a 15x6 +45 wheel would. I really need to find out the stock specs on our steelies...
1986 Nissan 300zx
1980 Kawasaki KZ650
2014 Kawasaki Ninja 300
1980 Kawasaki KZ650
- Fri Aug 14, 2009 3:27 am
#137842
some of those adapters are kinda thick which will be adding more negative offset to the wheel. You didn't mention adapters before... you may have a fitment problem with these on your car + adapters...
nice buy though
nice buy though
