- Fri Dec 10, 2010 7:13 am
#227100
Update: replaced the main fuel relay...no luck. The engine rotates but doesnt start. I checked the spark plugs, wires, dist cap all looks good. no cracks or anything unusual. Next I will be replacing the fuel filter and go from there. Hopefully that will do the trick.
take a plug wire out and stick a screw driver inside the plug wire
and then hold it near a bolt thats grounded which is anybolt and then have someone else crank the car, you will see the spark if this dizzy is good, but no spark means something in the dizzy is bad
