- Thu Sep 10, 2015 12:41 pm
#355776
Loaf, while you have the suspension torn down, change the old bushings if you can. I did all of mine when I did the conversion from drum to disc in the rear and also when I changed the LCA in the front and rear to add the sway bar . Big difference.
Drive it HARD !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
viewtopic.php?t=28277
needs to be tweaked a bit. your sedan is lookin real nice nowadays!
