- Thu Dec 05, 2013 6:19 pm
#339689
mitch6 wrote:juls1488 wrote:gtstripes wrote:sorry guys been busy with work
went to a car show and organised a guy to meet me there as it was halfway between us aaaaaand picked up these mofos!!
integra type R rims wrapped in BRAND NEW falken ze912 paid dirt for them ;) worth the wait for these
i can finally get rid of my horrible pink rims haha
nice snag!
do you have the 4x114.3 conversion, or are you gonna use adapter/spacers?
Good point lol, I just assumed he has the spindle conversion with them. Yea, these will not fit 4x100mm bolt pattern, you will need 4x114.3mm, so if you dont have the spindle conversion, you will have to purchase some wheel adapters. These adapters will also space you wheels out, so better make sure you take some measurements so you dont rub
Unless of course, you already have a 4x114.3mm spindle conversion?
^right. i do have some measurements to make it a touch easier.
to use spacer-adapters for these wheels, you'll need a 20-25mm adapter. the stock wheel studs are 25mm in height from the surface of the rotor, and the 96spec type R wheels are a +50mm offset. i use 25mm spacers on mine, which make the offset +25mm and i don't have any rubbing issues.
25mm is the largest you can go before you need extended wheel studs.
i would say 20mm is the smallest adapter you could get, since the back of the wheel is really shallow.
OR,
just do a full 96 spec type r conversion. then they'll just bolt on.
hope that helps!
