chewse wrote:While I respect your opininion I'm speakin from experience here...I know too many vehicles al l different  makes and models who have had their thermostats removed which helped their engines I'm not sayin to go out and remove your thermostat I'm just sayin if u ever have cause to remove it there's no reason to put it back unless u gotta worry about cold temps...and we all know that not everything a manufacturer puts on an engine is designed for optimum performance ( ever heard of de-tuned engines and the plethora of restrictors) in a nutshell thermostats are a bit overrated especially on older engines
Maybe older engines that are not electronically controlled, like ours are. So therefore irrelevant in this case.
The thermostats job is to keep liquid in the radiator long enough to cool it. The manufactures have set a certin temp that the engine can run at before it needs to be cooled. If the operating temp of the engine is below the thermostate temp level (say 180 degrees), there is no reason to try to cool the engine down lower than that temp.
When the thermostat is closed the coolant in the radiator will continue to cool. Even if the outside temp is 100 degrees it will still be cooler than what your engine temp is. When the temp outside is in the higher levels it will take more time for the coolant to cool while in the radiator. By removing your thermostat, you create a situation where the coolant never sits in the radiator long enough to reduce the temprature of the coolant. Essentially the coolant is constantly circulating and never cools down. You will most likely see a rise in the operating temp.
This is not only my personal opinion but my professional word as well.
