- Thu Aug 12, 2010 3:29 am
#208558
I have a quick question. I just replaced my UCA, LCA, inner/outer tie rods and accompanying ball joints and went in to get an alignment. I knew my toe was bad and it got worse after the tie rod changes, and I got the same thing from the tire shop. "You need camber kits." To appease the guy I said, I know but for right now, just adjust the toe.
front drivers side was -1.3
front pass side was -3.69 (OUCH)
camber is:
-1.(something) on the drivers side, f/b
-2.(something) on the pass sde, f/b
The toe was set to 0/0 all around but now the car wants to drift to the left. Any one have any insight on why it would be drifting. before the hardware replacement/alignment the car ran straight but with the excessive toe wear.
And for those that asked, I found this:
Wheel Alignment Specifications
* Camber – Measurement in degrees.
o Front: 0 (range -1 to 1)
o Rear: 0.33 (range -1.33 to 0.67)
* Caster – Measurement in degrees.
o 1.17 (range 0.17 to 2.17)
* Toe-In – Measurement in degrees.
o Front: 0.00 (range – 0.16 to 0.16)
* Toe-Out On Turns – Measurement in degrees.
o Inner: 41.00
o Outer: 33.50
Torque Specifications Ft. Lbs (N.m)
* Rear Control Arm Adjusting Bolt: 48 (65)
* Spindle Nut: 136 (185)
* Tie Rod Lock Nut: 41 (55)
* Wheel Lug Nuts: 80 (108)
