- Fri Jul 31, 2009 2:47 am
#134446
Well I guess this thread is long overdue, as I've had several requests to make a thread like this.
Despite the myths that have been perpetuated since the mid-90's, camber kits ARE NOT required to prevent uneven tire wear after lowering a Honda. Even the very first issue of Super Street magazine in 1996 talks about installed camber kits to prevent tire wear.
Here's what really happens. When you lower your Honda, especially those with double-wishbone suspension, the camber angle goes negative, but the front tires also toe out. That toe-out condition is what is important. Toe-out will destroy the inside edge of a tire MUCH faster than negative camber ever will, because the tire scrubs on the pavement as it rolls in a toe-out condition.
So the myth has been that you need a camber kit to bring the camber angle (non-adjustable on most Hondas) back to stock specs. So you install a kit, take the car to alignment shop, and *poof* no more tire wear. However, what really happened is that along with adjusting the camber, the shop also adjusted the toe. That toe adjustment is what REALLY saved your tires.
The truth of the matter is that you have made your car handle worse with straight-up zero camber (or close to it). It is also truth you can easily run -1.5, -2, -3, even close to -4 camber up front with very little tire wear issues. You just need to be sure to keep your alignment in check and rotate your tires every 5K miles or so. You should get an alignment at least once a year, or better twice a year if possible. All you need to do is get the toe adjusted back to stock specs. If the shop tries to sell you a camber kit, tell them no, just adjust the toe. If they say they can't do the alignment until you get a camber kit, then leave immediately and go to another shop because that is 100% COMPLETELY FALSE!
So let's talk about the "cons" of camber kits:
1. Cost, plus the extra cost of alignments every time (could be $150 or more)
2. Usually made of sub-par materials that rust, corrode, and seize up
3. Greatly reduces suspension travel clearance, both UCA replacements and just the bolt-type kits
4. Bolt-type kits are nearly impossible to keep straight and adjust correctly without throwing caster off
5. UCA-replacement kits often use POS ball joints and have even more reduced clearance under the fender
6. Likely to slip out of adjustment, requiring another expensive alignment
What are the "pros" of camber kits? Well you can add MORE negative camber than what you get from lowered suspension geometry alone, which can be good for track use. Other than that, I can't really think of anything.
One exception: 96-00 Civic rear suspension has a pretty steep camber curve, and could benefit from slightly reducing the negative camber in the rear from what you get from a drop alone. I would recommend the replacement rear upper arm-type camber kits. Those use a turnbuckle-type adjustment that will not slip.
Here is some personal experiences:
And now for some personal experience. I lowered my car back in early 2002 and had about -2* camber up front. I've been on various suspension setups since then with anywhere from -1.5* to -2.8* front camber and have NEVER used a camber kit. Since then I've driven about 175K miles, and I've only been through 5 or 6 sets of tires. I've always used V or W-rated summer tires, and they always last 30K-35K miles.
Now I do get a slight bit of inner wear, but I attribute that to my worn stock bushings that aren't keeping the toe in check like they should. I have all new bushings waiting to go in and I expect tire wear to be even less than before. But my tires do usually wear down past the wear bars before the inner edge shows any belts, so at that time it's time to replace the tires anyway.
I know there are many others on this site who can relate similar personal experiences. I'll let them chime in if they want.
Well that's about all I can think of to say. Hopefully this will help to dispel some of the myths. Hopefully I can help some people keep some extra money instead of wasting it all on camber kits and expensive alignments.
once again, Not mine, just something I agree with.
1986 Nissan 300zx
1980 Kawasaki KZ650
2014 Kawasaki Ninja 300
1980 Kawasaki KZ650
