- Thu Sep 11, 2008 3:00 am
#69227
Ok, i heard that u should retard the timing on a vtec d16 as it helps out ?? is that just be passed on or is it true ? and if so does it have a negative impact ?
What would be the correct timing 0 , so 1 retard is good for what ?
Thanks also is there any other timing trick and i mean by tricks is dyno tested that is help when u advance or retard and how much ? thanks
someone said it somewhere.
