- Mon Mar 31, 2008 3:49 am
#48453
Those with the rear foglight switch..
know what each of the 5 wires do? from top to bottom? thanks!
EBT WeSt wrote:I dont think i ever seen a pic of an EG with rear foglights...pic
SlipCivic wrote:Dumbass, it's a UK thing only. I'll see what I can do, but I don't have a car manual and CBA to rip my dash out.i dont think you needed to call him a dumbass, so chill out with that shit.
LowTEC-Derbo wrote:Trying to be UKDM!
here are the rear foglight pics courtesy of graham. Thanks again!
I did a minor review of the differences between them as well.
as you can see the USDM on the left and the UKDM on the right. The USDM has a more even red lighting to it.
further inspection when opened..
UKDM has nothing behind the red.
USDM has a white diffuser in the middle.
On the bulb holder you can see the UKDM has a reflective metal lense where as the USDM has nothing.
USDM uses a dual filament bulb 1157 where the UKDM uses a 1156 single.
Another note is that the harness has 5 pins.
which I am lead to read from left to right:
1.Parking Lamp Power (red)
2.Brake Lamp Power (green/yellow)
3.Reverse Lamp Power (green/black?) forgot already ahha
4.Ground (black)
5.Rear Foglight Lamp (Red)
USDM uses only the 1-4. UKDM uses 3-5.
I repinned my UKDM one to run off 1, 3, 4. I will make a harness soon enough so I can use a switch and make a hybrid USDM one which will have 1, 3, 4, 5
Here are pics of the pins ends
USDM
my repinned UKDM one where the red would've been at the right side.
and end result!
This gave me some random insight on how to make a USDM one into a UKDM. The part numbers on the outer lenses are IDENTICAL. The only part that is added is that white diffuser.
thanks homie.
Bouli wrote:I removed my fog light![]()
What exactly do ya wanna know ?
LowTEC-Derbo wrote:Bouli wrote:I removed my fog light![]()
the foglight switch has 5 wires going to it... where do they all go to?
