By stefan
#42814
By bangballs
#42815 then i put the 3inch thermal exhaust
and went on a shopping spree. purchased a new radiator and fan
intercooler, intercooler piping
oil sandwich plate and temp sensor
hondata s200
new headlights and corner lamps
By bangballs
#42820 then i put the turbo and manifold on . i purchased a turbo rebuild kit and rebuilt the turbo bearings and seals.
new plugs ,wires, dizzy, radiator hoses
By bangballs
#42821 then i had some piping welded but couldn't decide what i wanted
or this o yeah got these wheels fo 100 bucks
By bangballs
#42822 after searching 4 months for someone to socket the s200 i got it done but waited 2 months for it :cry: . then decided i didn't want it .. so not even 2 weeks later i sent the ecu and hondata and upgraded to the s300 :woot: and it was well worth it . but these are the things you go through when your a noob
By bangballs
#42825 got a center console, itr shift boot, and armrest. then i purchased some gauges and an a pillar. bought wires for gauges, torch, solder, shrink tubeing and went to work.
By bangballs
#42839 well this is my current state . i decided to go with this intercooler piping
do you guys have any opinions on what bov to go with
By bangballs
#42841 after getting everything put together. i got a base map on the s300 and finally got the car running only to have the clutch burn up on me after 5 minutes. once the weather warms up i'll go ahead and replace it.
#42843 Sweet build man, keep up the good work!
By stefan
#42860 I'd go with the new HKS SSQV, I love that thing :)
But just as long as you stick with the established names, you can't go wrong.
By DannyCraQ
#42899 damn the back end on the first hatch is so sweet, those are s2000 lights correct?
damn thieves
good shti tho :thumb:
