FS: Eg8 oem headllights+tail-lights, oem air intake box, jdm amber corners, d15 shaved/chrome valve cover, gauge cluster, sri, dc sports header
- Tue May 13, 2014 1:45 am
#345563
- Tue Jun 17, 2014 4:23 am
#346513
Mini-update:
I've got a bit of a vibration coming into the steering wheel, so I started troubleshooting. Balanced the wheels, rotors are new, bushings looked ok, but my drivers side axle pops and the boot seems to have leaked most of it's grease.
So, got a new set of swap axles coming.
A/C stopped blowing cold (went up to 62 degrees). Found out it's leaking from the R134 conversion adapters. Gonna evac, swap them out with new ones I just picked up, clean up and vacuum test, then recharge and see if that works better.
Other than that, She's still running strong and bouncing off the 9000 RPM redline.
- Thu Aug 07, 2014 4:34 am
#347726
Getting High, Sitting Low
My Build http://civic-eg.com/viewtopic.php?p=339056#339056
- Sat Aug 09, 2014 10:33 pm
#347770
Quick photo update as I dump pics off of my phone.
Few recent shots of the engine as it sits... I NEED to redo my valve cover! LOL
And I had a little bit to mess around, so I put one of the hatchback wheels onto the sedan to see what it would look like. Aside from needing to be lowered, I think it looks pretty damned good.
- Thu Aug 28, 2014 7:54 pm
#348358
I'm about this close to tossing out my Skunk2 alpha throttle body away and getting a BWR or Edlebrock throttle body. I'm pretty positive it's causing very slight idle issues still, not to mention that even though I multimeter tuned my TPS to read perfect half a volt idle to WOT voltage, it still causes the TPS CEL to come on and stay when I floor it. It clears when I shut the car off, but it still bothers me that something might be off with it. The TPS is a factory sensor, btw, since Skunk2 doesn't come with one.
