By backyardbikes
#300487 here are the pics of the lca's installed, eventually i will take them back off and power coat them red. also the gsr cluster.
By backyardbikes
#300676 well yesterday i was messing with the car, checked all my belts, they looked all cracked up and shitty so I went ahead and replaced them. while doing so i noticed my timing belt was really loose. I went ahead and tightened that as well. I also filled my drivers side torque mount because it was super loose and one piece was broken. the car feels smoother, and seems to be picking up better. there was a ton of slack in the timing belt so maybe that did it.
next upgrades will most likely be rear and front camber kit.
By backyardbikes
#301634 not the prettiest but it definitely stiffened up a good bit. ill put it in tomorrow and see how i like it. pass side is next :)
By backyardbikes
#302074 finally got to chipping my p06 ecu. it was pretty easy once i got using the solder sucker and the soldering iron at the same time.
