By 603 jdm
#254219 well u might be able to but u would have to definitally cover up the electronics really well. id just assume to use a reg hose and get elbow deep in that bay and scrub the hell out of it haha :thumb:
By 94EJ2
#254220 perfectly safe to pressure wash your bay i do it all the time to my car just leave the car running and dont spray directly on your distributor or fuse box
By nateski
#254261
By 603 jdm
#254283
By ghskid06
#254286
By 603 jdm
#254290
By nateski
#283727 do i have ABS brakes?:?
i looked through the chilton manual and it suggested to look at my instrument panel and see if my ABS light turns, witch i did. NOTHING TURNED ON. i dont think i have ABS but just to make sure i figured i ask you guys. just wondering because i need a new wheel bearing. i bought my wheel bearing from a local autopart store and he asked if i had ABS and i wasnt too sure, so i went ahead and told him yes. i also dont even know if i have disc or drum brakes lol. but im pretty sure i have disc in the front and drum in the back right?
also whats a automatic transmission fluid that you all suggest?:?
i used dexron III witch i think was a bad idea because my tranny is now stuck in first.
thanks to anyone that replies!!!:D
By PhantomEJ1
#291966 Wow you found yourself a really clean coupe,! And with no rust at all that's lucky. If I was going to suggest something it would be getting the rear qtr panel lips covered with some bedliner like line x or something good to prevent rust from ever happening cuz if it ever starts it will ruin your day, trust me! Other than that it looks good, keep it going!
By PhantomEJ1
#291967 Wow you found yourself a really clean coupe,! And with no rust at all that's lucky. If I was going to suggest something it would be getting the rear qtr panel lips covered with some bedliner like line x or something good to prevent rust from ever happening cuz if it ever starts it will ruin your day, trust me! Other than that it looks good, keep it going!
