By phatboycrxhf
#244854 slow moving as of late guys :?
last night i took the engine harness and laid it out.think i may have the wrong harness though,i have an extra plug on both sides of the harness and i'm not to sure why and from what i remember the vx harness didnt have extra plugs ...hmmmmm
also found a cut plug,the injector plugs ahve to be redone ,the speedo sensor has to be swapped from the vx trans to the si (hope it works) also the harness seems way to long....lol
this is my wifey and the one i'm building the ar for
she cameout in my old lugz...had a lol over it
crx is back inside with a very beat up an alot of surface rust
cowl hood im working on for it
reno/facelift pics ?
since the baby is coming i have to make my bedroom larger for the crib and whatnot,sooo i will be relocating the south wall out about 30 inches ,but in this pic i moved all my ovies and such into my living room untill that goes down (notice the john wayne pic) lol :thumb:
primed the drywalled and mudded walls,i have a few lifting of the tape issues,by the window i have to redo and or fix...but looks way better thus far i think...
i also got a new tub...well new to me...this is an old ass claw tub with shower curtain holder and shower rod,the tub was made in 1913 people haha and weighs 300 lbs :shock: i'm going to restore it and put it in the bathroom after i reno in there in the fallowing months ...just need to dry wall and laminate in there frst
classic taps,but not original,obviously have been changed ,since i found the exact same ones for sale for 150
i'm going to go for this type of look in the bathroom
i love the laminate floors
anyways i'll be out there working on something today,damn harness is pissing me off and wanted to have this car running by now :thumbdown:
By phatboycrxhf
#245132 thanks :) i actually do flip hondas for a living haha,i buy salvage titles and fix them .i also do rust repair on other cars.
so i have an issue,i think i have the wrong engine harness again,or im missing something i have two extra plugs on each side of the bay where if harness comes out of the wall...i'm thinking the dude swapped a full vx harness ,but maybe someone could shed some light ?
this one on the passenger side of the bay
this one on the drivers side of the bay
the o2 will have to be rewired
the speed sensor wires have been cut...
i'm going to have to make the TPS sensor wires longer ,like an inch or so
ummmm
starting to think i should have just tucked the harness a lil bit :(
i did more work on my place too ,since the baby is coming i made the master bedroom bigger since i have to fit a crib and change table and such,so this is what i did
rounded wall
temp walls untill i put new drywall (truck s full of junk)i'll be buying more next week sometime
lol notice the old door just chilling covering a wall hehe
oh and monster stickers for the bay
oh and i got a neuspeed front strut bar for the monster as well,gonna strip it and spray it in orange probably
By phatboycrxhf
#245594 i got the battery relocation wires all togetherand the multi amp wireing kit as well ,but i cant take a pic because of my dang woman killing the batterys !!!
By phatboycrxhf
#245753
By phatboycrxhf
#245819 battery relocation wires and amp wires
ek mirrors ? :S lol
new light switches and plugs for my living room and kitchen
By kapow
#245882
By phatboycrxhf
#245989
By phatboycrxhf
#246097 alright i'm starting to get a bit fed up with the no cranking issue...so far ive checked the fuses,i cleaned the grounds and the mounting points and made sure they were tight,checked to see if maybe the neutral switch was broken,changed the starter,changed the engine harness and intake manifold...unplugged the ecu and checked the plugs ,like i'm running out of ideas here asto what the issue might be...it has to be a ground issue
there is only 3 grounds on the engine and trans correct ? the one on the thermostat housing,the trans an the head right ?
hmmmmm i wonder
i had to put the injector plugs back on this harness
this big ass can is just wicked
By phatboycrxhf
#246110 oky i went and check the neutral saftey switch again since i found this pic ,but is there suppose to be one or two of these sensors ? i have one at the top,but the pic mentions two,or at least thats what i gathered
i have the switch A ,but not b,i have the lock nut,but thats it,i don't see this being the issue since there would be some sort of plug or something to show that the sensor B was present at one point...
By phatboycrxhf
#246120 i gve up for the night ,i pulled te main relay(dont think its the issue) but i'm going to resolder the contacts tmw anyways
i made a jumper for the starter as well ,to try that again nothing...well the fan came on :o i dunno i'm lost here haha
i wonder if i got the engine bay fuse box wet or something...dont think so...
By Gunni
#246170
