- Sat Feb 26, 2011 6:54 am
#241040
- Tue Mar 01, 2011 12:20 am
#241548
took some more pics today. some that are closer in detail of the exterior. let everybody see how bad the damage really is lol.
the mounting plate for the pass. mirror is rotted all the way through. i'll get doors when i start on the exterior.
someone before me started the body work. but it's a very sub par effort. will cut off and replace.
this is a fiberglass patch lmao. and in the pic below, you can see right into the interior through the wheel well and the fiberglass.
driver's door has small dents and is way out of shape. will replace also.
this is the driver's side floor pan. don't know how it got bent, but pretty sure it's not supposed to be like that... i'll either get some sheet metal and patch the whole thing or find a donor in a junk yard.
didn't see the point of taking a pic of the new door handles installed.
- Tue Mar 01, 2011 5:20 am
#241590
- Sat Mar 05, 2011 1:56 am
#242313
i don't have a finished product yet, started getting cold, and it was kind of raining... will have a final product up tomorrow. my intake gasket was ripped too, so replacing that as well.
installed replacement, rented a freakin wheel remover and lock remover to find out my steering wheel wasn't even on tight....
going to wire up a S2K push button. may be rice, but i've always found them to be awesome and to each their own so...
found some microfiber in town finally, but it's $40 a yard. i need two yards to do my head liner. doing that next weekend as well as painting the pillar plastics. changed my mind on the interior. i'm going to go black. it's not all that expensive... dash and carpet is the worst part so...
- Sat Mar 05, 2011 10:46 pm
#242460
stayed up until 6AM putting my car back together. wasn't tired so...why not lol. LOOKS WAY BETTER.
when i took the intake off the intake gasket was broke in half. (was going to replace it with this, but didn't pan out right. still have to do it...) i noticed the shape of the ports on the head don't match the ports on the manifold. is this normal? or do i have the wrong intake on my car. if you port matched the head to the manifold i'd imagine you'd get a good improvement?! cause that's a lot of material you could remove and probly gain some better numbers.
- Sun Mar 06, 2011 1:23 am
#242483
Wow that rott is newfoundlandish
It is bad but buy the replacmnet panels and find a bet up door.Chop the door up from the body trim down and that will cover most of your quarter ;) All i ever do...It is gaurnteed to fit right
... Coming along nicely
- Sun Mar 06, 2011 1:31 am
#242485
i found panels for like $35 each, but they are aftermarket. honda has panels for like 135ish i think. not sure. might just splurge when it comes time so i know it's done well lol. i cut my teeth on wrenches pretty much so... just a matter of finding someone with a welder and GSD (getting shit done)
but thanks man.. it's my first solo project... learning a lot and this forum is so freakin helpful!
just slow progress cause i don't have a job... if i were in FL still i would have a full body shop at my disposal. (family body shop) every tool knowing to man kind = heaven.
- Sun Mar 06, 2011 8:18 pm
#242559
haha! if i take the side skirts off they might never go back on! i know the back side on the passenger side is straight F'd!
i've been looking on www.fixmyrust.com they look pretty nice for the price. can't beat 30 for each side lol. and then the rocker panels i'll need. and then the driver side floor panel. then i need to patch a hole on found on my firewall... everybody's gonna in for a ride lol. lots of work to do...almost though about just buying a sheet of CF and layering the shit out of it and using it as my floor panel lol, but...i'll do it with sheet metal...
- Mon Mar 07, 2011 1:04 am
#242612
what motor is in your car, D15b7? That is definitely the wrong intake manifold... maybe from a cx or vx?
I wouldn't even bother port matching... the whole intake will still have smaller runners, not optimized for your motor.
good news is you can get a D15b7 intake manifold for cheap. I think I even have one in my basement, the same one in this thread: http://civic-eg.com/viewtopic.php?t=3340
PM me if you're interested.
Also check to see what the stamping on yours is (p06, p08 etc..)
- Mon Mar 07, 2011 2:32 am
#242623
i've got a d15b8. i can't remember the stamping on it... i saw it when i was stripping the paint off...
i wasn't exactly planning on port matching it lol. just the thought of them wasting such space killed me! i've noticed my car has been kind of jumbled together...blue interior with a grey dash when it came with black. you know...small things that make you scratch your chin.
*edit* just checked my IM number. it's a P10?
- Tue Mar 08, 2011 3:10 am
#242848
before
after (there's a small gap at the bottom where the little rubber seal is. kinda sucks...)
not much to look at, but...this is now my pride and joy. that muffler is not permanent. i can't stand it lol.
also got my CC slider and new knob in. threw in a couple new CC bulbs and reinstallled my CC and stereo. i just don't like how hard my heat adjuster slider "slides". so for now, I've left it unhooked and will figure something out.
i'm thinking about saving some money for a little while and making some more major purchases, but there are still a lot of small thing's i want or need to do before i'm...let's say...satisfied. i'll be doing the upper plastic black, along with head liner, visors, and a front map light. i will most likely be doing the driver side floor panel, then i will worry about carpet, better seats and floor mats. might try and make some mats as well. i have a job interview tomorrow or wednesday so hopefully my resurrection will happen faster.
*edit* ...very boring thread at the moment...but things will spice up after i start working
before
- Thu Mar 17, 2011 11:43 pm
#244572
Team XXX Racing/WGHonda
- Page 2 of 3
- 1
- 2
- 3
