- Sun Dec 05, 2010 12:37 pm
#226122
can the above model front and rear seats fit nicely on our civic?
- Mon Dec 06, 2010 2:56 am
#226222
They will not bolt into place. However it more likely then not that you can weld mounts and be able to get it to fit into an EG. The Rear seats might be able to fit into a Sedan. Probally to big for a Coupe/Hatch.
- Tue Dec 07, 2010 2:16 pm
#226479
Any expert can confirm or has tried it on sedan??
I am told that the front seats are direct bolts.....
chrono404 wrote:They will not bolt into place. However it more likely then not that you can weld mounts and be able to get it to fit into an EG. The Rear seats might be able to fit into a Sedan. Probally to big for a Coupe/Hatch.
- Wed Dec 08, 2010 6:41 am
#226646
TSX's are the same width as Integras, which are the same width as EG and EK's so The rear seats should move across, However I'm not sure where the seams will be.
If you want easy to bolt in seat upgrades the EK Sedan Rear Seats(and Acura EL as well) rear seats are a direct swap out from what I have read.
I doubt all 4 holes from the TSX Seats will bolt right in, Especally since the RSX front seats dont do the same. You need to make mounts for them
- Wed Dec 08, 2010 8:08 am
#226661
correct i bought RSX front seats and thought they would fit my EG but only the 2 bolts in the back bolted on the front you would have to cut and weld
chrono404 wrote:TSX's are the same width as Integras, which are the same width as EG and EK's so The rear seats should move across, However I'm not sure where the seams will be.
http://civic-eg.com/viewtopic.php?t=17296
My for sale thread check it out!
http://www.civic-eg.com/viewtopic.php?t=25828
#3 CivicEG.com Ferio Squad
- Mon Dec 13, 2010 1:23 pm
#227619
Any ideas rear seats can fit?
Can post picture online?
familyEGuy23 wrote:chrono404 wrote:TSX's are the same width as Integras, which are the same width as EG and EK's so The rear seats should move across, However I'm not sure where the seams will be.
- Thu Dec 30, 2010 10:11 am
#230496
Bought EK rear seat and they are direct fit.
Which year of the Acura EL can fit also?
- Thu Jul 05, 2012 4:39 am
#310151
Still awaitng for expert's advice.
Need to change the interior......
