By david10072
#221820 Big clean up today, tear apart the interior and vacuumed everything. Cleaned out tons of hidden crap :eh:
Decided the fix the dent on the rear bumper and the fitment on the side.
It turned out that I had to spend around 2 hours trying to get those dam rusty bumper screws off. One of the screw, wont come off so I burned it with a torch. :thumb: Then the rear end damage was worse than what I expected. The foam is gone, the metal is bent pretty bad.
I heated up the bumper with a torch then tries to bend out the dent. It is not perfect, but good enough. Much better than what I started with :hehe:
Also fit the bumper up.
By david10072
#221954 Image
This is terrible :thumbdown: Good thing it was just a small rust. I sanded down with 40 grit. I am not scared!
Painted it with anti rust.
Bought those mesh at kragen for 5 bucks. Bent it to the right place as a foundation for bondo. I don't have the tools to do a proper rust repair, so I went with this method..
bondo the s*** out of it. 8)
sand it down, and match the body curve. :wink: it's not as easy as I thought it would be. Matching the original curve is difficult. This is my first time doing body work with bondo. I will try to get it better and post up a pic. :roll:
By david10072
#222133 Image
Put on the wheels. When I was installing the coilovers, I stripped one of the oem bolt on the strut. I spent few days trying to PB blast, torch, vise grip, hammer, but I gave up and send the car to a shop. Let them worry about it. and It turns out that the thread of the bolt was fine, it was the bolt rusted down with the bushing in LCA. so there was no way I could have loosen it myself...what a waste of time haha. Ended up cutting and drilling and replacing a new LCA. Quite expensive in a shop. :x
New corner amber :roll: My mud guard is scraping like crazy..Also, ordered some new rear rotor and rear brake pad (hawk performance), since my brake on the back is rusted out. What tools would I need to reset the piston? Where can I rent it? Any help is appreciated. I hope I won't strip another bolt on the caliper..
By Apexracing
#222134 The rear pistons screw in you can buy the tool cheap at a auto parts store
By speedracer1094
#222136 Good job man. Theres nothing like the satisfaction of working on your own car. :thumb: :thumb:
By david10072
#222247 Today I picked up some trim paint and started painting trims. Mirrors, wipers and trims.
Look better than the faded grey mirrors... gotta love the trim paint, restoring OEM color!
By david10072
#222393 Took out the cluster today, for a LED swap.
Sorry for the blurry pictures...the LED looks pretty nice from outside of the car too. :thumb:
By OleFolk
#222406 Not bad at all :thumb:
I like your rides
Im a student too, its a little hard to focus on your car.
or put any money into it.
By imtyson
#222441 may i ask where you got your LED bulbs from? :hehe:
By Gustavo
#222444
