#202037 Man that Crossmember was a B@#$ to get out!! We had to take it out with the FLCA's still connected and then my Dad cut a whole out so we could get them off... Well Here's a update of what I did today!!
Crossmember Done!
Sway Bar Before
Sway Bar/Brackets Prep
Tie Rod/Lower Ball Joints and Sway Bar Bushings-:)
Bronze Sway Bar Done!!
#202038 Tomarrow I will be bolting the Front Crossmember back on and replacing the Tie Rod and Lower Ball Joint Bushings. I also ordered some Inner Front Control Arm Bushings that will be putting on tomarrow as well. Then I am Hoping that the Coupe will be running again!!!!!!! :thumb:
#202076 nice, not everyone pays much attention to the suspension other then a drop/lowering
but if you got 3459083 hp and a shit suspension good luck hookin up
but very nice updates :thumb:
#202120 Thnx 94_jdm_ferio!! :thumb:
#202587 I didn't get to post these the other day. Painted the M/C Bronze and this is how the Brake Booster came out, its textured but u can't really tell in this pic. Also got new oem bushings in the FLCA in!!!
#202888 Almost there I got one FLCA in today after I got off work and I think by this weekend I will be rolling again!! Yee!!!!!!!! I will post pics later!! :woot:
#204691 So I got everything done last weekend!! But I have to go and get some new tires and get it aligned....This weekend the Coupe should be back on the road and then I will saving up for a paint job!! YEE!! I will post pics this weekend or next! :thumb:
By chilango41
#205355
Punksz6 wrote:I didn't get to post these the other day. Painted the M/C Bronze and this is how the Brake Booster came out, its textured but u can't really tell in this pic. Also got new oem bushings in the FLCA in!!!
Is it hard to take this off^^ and put them back?
#205359 Thnx for the comments!!
No its pretty easy u just gotta make sure that when u take the Master Cylinder off that u use a Flare Nut Wrench to unbolt the brake lines!!! U cant just use a box end wrench because it will strip the nut and then its a @#$@ to get off..
And for the Booster there is a Pin that is under the dash on the drivers side, where the booster connects to the brake pedal. U have to push that out before u can get it unbolted and out. Oh and I had to take off some things like the throttle bracket and booster hose bracket.When the booster is unbolted out have to move it around (Pull it toward the Intake Manifold but try to get it under a lil then once the part that hooks to the pedal is out then just slide it out) to get it fit through the Intake Manifold if u have it in there. Move ur brake lines too cause they will be in the way.
It would probably easier if u had the engine/motor out of the car.. :thumb:
Oh and when u put your new or replacement M/C back u gotta bench bleed it to get the air out of it!!
By Fada Blayne
#205419 BUMP!
planning on doing my brake booster,etc this upcomming weekend as long as its nice out
#205519 Nice!! Post pics during and after! I would have but my Wife broke our camera! If u need help just ask! :thumb:
#206142 So I need two tires before I can get my Alignment done! I did a couple things today like put on my rear mud guards I picked up for $5..I also touched up the bay a lil and put the Benen radiator stay on...I am going to tuck the headlight wiring and I also put the Benen ECU cove lid on! I am hoping to get the tires by the end of the week and also plan on getting pics!! :thumb:
#207327 So I picked up a set of 2005 Civic Rims with tires!! I also got the drivers side headlight wiring done!! I am gonna get the passenger side done by this weekend and then the alignment! I'll post pics later!! :thumb:
#207861 heres the 2005 Civic Rims...I am gonna clean them up and take that bad paint job off...I might get them back to stock or maybe bronze? The caps were painted too so I might have to get new ones..
Sorry for the crappy cell pics!
