By Flanders43
#149088 Picked the car up few months back for $500 1995 Ex coupe with a sohc vtec 80k no rust car was real clean and is sitting on koni yellow struts with ground control springs..
Since then i have pulled the sohc started to clean up the bay doing a headlight harness tuck then going to shave it and start building a nice LS-v setup on the side, have also put in Blox LCA'S, ASR Subframe brace w. sway bar (no pics yet), also put on a Greddy SP2, Black housing headlights w. amber corners, Yellow fogs, Rear diffuser, 50/50 tails, few other things here and there finally getting motivated to get this project done.! lmk what you think so far will get some updated pics asap..
These holes will have patchs made and welded in when i end up shaving the bay.. im not going crazy with the firewall im going to keep the brake lines etc alone, washer fluid holder will be moved.
By Dippin_EG
#149101 great start. post up some engine pics. 8)
By thecrow
#149102 good stuff!!!! i can dig it! :thumb:
#149103 :thumb:
#149187 welcome and you have a great start for a nice project :thumb:
keeping it black? 8)
#149240 great start and good luck, can't wait to c more :)
#149291 Looks like a good base. You have some good plans for it to. I would recommend a b16 tranny for your LSvtec if your planning on staying, N/A. It will give you the best acceleration for the readily available B Series Transmissions.
I would also recommend spray painting your front bumper and the grey cut out brace. Even if you use cheap spray paint, It will make it look so much better being black.
You have cutout holes in your back bumper to reduce drag. Unless there is a rear diffuser under the rear of the car we cant see in yout pictures, Then it doesn't look like you have diffuser.
Image This is a Carbon Fiber Diffuser, It molds the air straight out and up so it will suck the rear end of the car down for better traction and keep it stable at high speeds.
By PandaHatch
#149363 Car is nice man but that rear bumper with the cut out and plate just makes it look sloppy. I would recommend getting a real diffuser and you may be able to fit the HOP rear diffuser for an eg. here is the link if your interested.
http://www.jhpusa.com/store/pc/viewPrd. ... oduct=3699
By PandaHatch
#149403
