- Wed Jul 22, 2009 11:07 pm
#132506
well just look in the main spot like the cylinder wals, crankshaft area were it sits, warped head. best thing to do is if you get a bare block, take it to a shop and let them make sure it has no cracks and that the block is not warped. other than that it will be visible damage...
- Wed Jul 22, 2009 11:21 pm
#132513
um i dont have any. but like i said. any reall damage will be visible and can be see. if it has any small cracks or warped head then a machine shop has to find them. you cant see the head being warped and sometimes cant see the cracks. as long as it does not have a big ass hole blown threw it, then its proably good. what exactly are you doing??? plus you need to change your title. ls block has no meaning to what your looking for... try "whats a damaged block look like?"
- Thu Jul 23, 2009 1:34 am
#132561
here's a pic I have of a bad block:
My 1992 SOHC Turbo Hatch
- Thu Jul 23, 2009 8:11 am
#132635
^^ shooo thats nothin a lil duct tape cant fix
but like egsedanguy said you should take it to a machine shop and have them check it for you
but check the cylinder walls for scoring
make sure its not warped
make sure there aint a big ass hole in the side of the block lik the pic above
check for deep sratches or notches or any chips on the crank and where the crank sits
but you best bet is to take it a mechine shop and have them check it
and if its good while its there have them hone it, deep clean it, and all the good things they can do to it
- Thu Jul 23, 2009 1:50 pm
#132667
i love the hole in the oil pan
damn teal did you do this yourself?
teal_dx wrote:here's a pic I have of a bad block:
- Fri Jul 24, 2009 3:24 am
#132876
it was a take the tranny, get a blown up d16 with it deal
- Fri Jul 24, 2009 3:37 am
#132881
well then free head and oilpan already with a hole for a oil return do i smell turbo or is that just burnt oil....
teal_dx wrote:it was a take the tranny, get a blown up d16 with it deal
1980 volvo 242
2001 crv
2001 crv
