By smokinsoljah420
#109135
hatchie wrote:also how do you jack your car up being that low?
i can barley do it now?
Low profile jacks FTMFW! i dont know how i would survive without one! lol! :thumb:
By hatchie
#109140 where'd you get it ?
By VegasCivic
#109147 Get a good alignment . Toe kills tires x10 faster then camber. Depending on the tire itself will also determine the wear. Remember that :thumb:
#109157 15x6 +45 offset(Fat Fives, Meshies, Blades) vs your 16x7 0 offset.
Your wheels will stick out 58mm more and you will have 32mm more inner clearance.
Good luck being lowered with those. thats almost 2.5 inches.
By hatchie
#109163 my rims only stick out a quarter inch not even and i said it might be 0 offset i could be wrong
VegasCivic wrote:Get a good alignment . Toe kills tires x10 faster then camber. Depending on the tire itself will also determine the wear. Remember that :thumb:
x2
I love Negative Camber, Helps so much in the Turns. Toe changes when you lower your car. Toe wear is what kills your tires. So when you lower it make sure toe is set to "0" and your tire life will be much longer.
:thumb:
This info has already been posted. Just wanted to back it up again. :thumb:
By hatchie
#109176 theres a couple ppl on the internet that have tucked sportmax rims before so i deff believe i can
ok my offset is 38 i just did more research on them
here a pic with my rims tucked on diff car of course
By Civic_HatchSI
#109219 I have been having rubbing issues forever! I ran 16" with 205/45/16s for two years with a 3" drop.
I recently installed a set of 15" with 185/55/15s and have no problems at all!!! My car is as low as it can go with no rubbing :0)
I still have my camber kit up front and in back, but yes the tires do wear quick on the inside with out one.
By Vti93T
#109223
Civic_HatchSI wrote:I have been having rubbing issues forever! I ran 16" with 205/45/16s for two years with a 3" drop.
It doesn't matter if you have a camber kit or not. A camber kit is not going to save your tires from wear. Getting the toe adjusted will save the tires.
hatchie wrote:theres a couple ppl on the internet that have tucked sportmax rims before so i deff believe i can
with the +38mm offset, it will stick out 20mm more than say a LS meshie, so it totally doable.
By zeppelin101
#109288 If they had been ET0 you would've recieved immediate baller status for pokey out wheels and stretch. I would have demanded arch pulling antics to occur also if this was the case.
However it's not. I hate tyre tucking personally and low offsets with stretchu and arch work is the way forward.
I will demonstrate this on my next motor.
By hatchie
#109391
zeppelin101 wrote:If they had been ET0 you would've recieved immediate baller status for pokey out wheels and stretch. I would have demanded arch pulling antics to occur also if this was the case.
please explain in dumb words for me :lol: like i said im still a newbie to this whole thing soo some terms or words you using i have to google them lol
but anyways so all i have to worry about right now is the fact of rubbing with 16's?!?! right?
By Vti93T
#109421 yeah because if you are going to lower it to tuck tire then you are probably going to rub.
By hatchie
#109425 it'll prolly only rub on he fender liner though right not a big deal though?
By Graham
#109466
Dippin_EG wrote:Mad camber= mad tire wear=more money on tires=less money on good honda parts= mad honda enthusiast = camber FTMFL.
Fail :thumbdown:
