- Sun Mar 15, 2009 6:34 pm
#103442
-It is illegal for the driver to watch movies without the e-brake set. This how-to will show how you can watch movies while driving.
DO THIS AT YOUR OWN RISK!
First you need to unscrew 4 screws that are holding the panel you need to get behind.
After removing the 4 screws, it should be able to be pulled toward you, but be careful and not pull to hard as the cigarette lighter is connected. So disconnect it.
After disconnecting the cigarette lighter, move the bottom piece to the side. It should look like this now:
Next locate the pink wire that says brake on it. This is the wire that we are going to ground to make it possible to view movies and drive at the same time.
Now just grab some speaker wire and some wire connectors, strip the tip of the brake wire and the speaker wire and connect it with the wire connector.
Next, you can either make a ground or find a place that already has a ground. Luckily, when I removed my Sunpro tach I left the previous ground wire, so I stripped the tip of it and connected the remaining half of the speaker wire.
Now connect your cigarette lighter and screw in the 4 screws. Now you can watch movies while you drive.
Pm me if you have any questions.
enjoy
enjoy
Here you can do whatever you want as long as you don´t crash or act like a drunk ;)
I guess they look at it as an obstruction while driving. I have heard of people getting tickets and what not, if the cop see's the "video" he can pull you over and give you a ticket.
