General exhaust discussion & questions
#323665 I trust Magnaflow's name more than I trust OBX. OBX has made some not so great quality parts in the past.
#324186 Magnaflow cats are crap. They are rebranded from another company so you can't transfer the brand loyalty. I have said this many times on this forum and it is based on my experience owning 3 Magnaflow cats and being an I/M Safety Technician. A Magnaflow cat will get you through a single smog check and you'll fail the very next year. The only exception is on a motor that runs so damn clean it could probably pass without a cat converter at all. I have found that all JDM engines run high NOx.
You're better off with whatever cat the exhaust shop gives you. Weller etc. Stay away from "high flow" gimmicks.
By rustyrex
#324237 go to www.autozone.com and find the cat that is made for your car. in the product description it will say "Direct Fit", write down the part number, then go to ebay and search for that part number. just a heads up i bought my header with cat for my 00 lx at www.rockauto.com for $188. and it is the same exact brand that autozone sells but, autozone wanted like 600 bucks for it.
#324558 The "High Flow" cats that you see on ebay are cheap because they do not always have the proper elements inside to do their full job, compared to an OEM or quality aftermarket cat. Catalytic converters use very expensive/rare metals in the honeycomb element located inside the cat in order to do their job. I don't know the exact science of how they work, but that's why a real cat is so expensive. The "high flow" ones have less or none of the element inside. You get what you pay for :thumb:
Also, 25,000 miles is not much of a warranty. Heck, in Ohio, cars are only required to pass e-check every other year. Average person drives something like 14k mi/yr. You wouldn't even know your cat failed until 2 years later when you go back in for emissions check and your car fails emissions. The OEM cat on my hatch is 20 years old with 180,000 miles and my car passes factory emissions at e-check... WITH a turbo!
You get what you pay for, so if the one you can afford comes with a 25,000 mi warranty... might as well get the cheapest one with that warranty since I don't see it lasting too long. :thumb:
By kylenjdm93
#324635
By HagerSol
#324800
