b16a trouble?? ='[
Mon Apr 06, 2009 4:59 am
by 95civiceg
hey every one idk wats wrong with my b16
it makes some sort of ratlle sounnd and its just too loud
heres a video of my engine
http://www.youtube.com/watch?v=05DKxg-SO10
Mon Apr 06, 2009 3:50 pm
by _gash_
im not supermech, but sounds like it ent firing right and maybe ur exhast manifold is leaking but i dought that would cause it to fire like that, what tests have u done so far
Mon Apr 06, 2009 8:49 pm
by platnuim86
it sounds like staged cams to me but
not sure
Tue Apr 07, 2009 7:06 pm
by 95civiceg
well i just looked at my headers and i noticed that the bolts that hold the header with the down pipe
that one is missing so im guessing thats what causin it to be loud
i have not done any test on it yet
it has the check engine light on
and yes my car does have different cam gears
it has some VENOM cam gears
idk if the cams are also VENOM
or stock how can i chek
Wed Apr 08, 2009 3:52 am
by Dippin_EG
take the cams out and measure the lobes with a micrometer or dial indicator.
there could POSSIBLY be a stamp on the camshaft.
Wed Apr 08, 2009 2:18 pm
by colpitts
i'd say get a wiring diagram, make sure that the wires from the dizzy to the plugs are in the right order and check/reset the timing. tighten that bolt on the header and see if doing the above changes anything.... also knowing what code your CEL is throwing would be a help too..
seems like it idles funny and high, especially after you give it a little fuel.. i'd check vacuum lines too..
