summer swap
got all the plans worked out for this summer. going to be doing a b18b1 swap boosted. buying it from a guy thats gona swap out his motor for a type-r motor. the whole swap comes with a lot of extra parts.
B18B1
'99 SC4 trans.
Action 6 puck kevlar clutch
Action 8.8lb Flywheel
Action HD pressure plate
Topspeed Pro1 4-1 SS header w/2.25" collector
Taylor 8mm ignition wires
Crower valve springs
Spoon thermostat
B&M FPR
Mild intake/exhaust porting
Crane stage 2 cams
MSD cap and rotor
New water pump, oil pump, timing belt, idler pulleys & tensioner
Axels, linkages, mounts, ecu & main harness
^all of that for $1700
Turbo Kit
Garrett GT22 .67 a/r
Turbonetics external gate
Ebay IC pipes
JDMSport FMIC
MEGASQUIRT v1
450cc injectors
GReddy RS BOV
Greddy Profec B Spec II
Dual gauge pod w/ oil pres. and boost gauges
^i picked up the IC pipes, FMIC, megasquirt(presassembled), 450cc injectors, gauges and pod, and RS BOV for $500
B18B1
'99 SC4 trans.
Spoon thermostat
B&M FPR
Crane stage 2 cams
MSD cap and rotor
Turbo Kit
Ebay IC pipes
JDMSport FMIC
MEGASQUIRT v1
450cc injectors
GReddy RS BOV
what a deal!!
