- Thu Dec 04, 2008 3:12 pm
#81952
My car idles from like 1500 and then goes all the way under 1000rpm and just continues to do that also sometimes itll idle soo low that the car will turn off im not sure what it could be i know the timing was off but we fixed that and the car has enough coolant and there doesnt seem to be any vacumm leeks but i could be wrong what could be causing this idling?
- Fri Jan 30, 2009 6:42 pm
#93318
search function?
#3 Member of CHANCE is HOMO club
marvinp8700 wrote:in for chance is a homo club membership
hatchie wrote:you have to believe it to be in it
Chance wrote:true story
- Fri Jan 30, 2009 7:00 pm
#93320
all fuel injected cars will idle high for a few minutes when it first starts up. to help it get to operating temp. but it should go back to normal idle
95 lx sedan
88 rx7 base sold
93 del sol swapped b16a2-R.I.P
i'm addicted to 8200 rpms
"car inspection, what's that"
STDs cause you to fart lighting bolts.
88 rx7 base sold
- Fri Jan 30, 2009 11:28 pm
#93396
idle control valve, idle position sensor... could be one of those 2.
there is also a small screw on the throttle body, that can some times get loose to try adjusting that.
94 civic sedan, got camber?
- Sun Feb 01, 2009 8:21 pm
#93660
yea but those screws rarely come loose go with one of your sensors first.
95 lx sedan
88 rx7 base sold
88 rx7 base sold
- Tue Feb 03, 2009 1:56 am
#93874
screw = free to check and fix
sensor = potentially expensive to fix...
go for the screw first...
