Page 1 of 2
b18 all motor power
Sat Oct 18, 2008 6:09 pm
by LaMbErT*
How much power do you think id be able to get out of a b18 without turbo. Would like some help, i will be doing a b18 conversion next year sometime and id like to know what i can do to get as much power out it as i can from pistons to intake and so on if anyone can help
Sat Oct 18, 2008 6:33 pm
by Faded_Milano
B18...B? C? A?
Sat Oct 18, 2008 7:39 pm
by LaMbErT*
itll be a b18c mate
Sat Oct 18, 2008 8:30 pm
by Greasedmonkey
Depending on how you build it you can get 240+ out of it.
Sat Oct 18, 2008 8:52 pm
by LaMbErT*
you see im looking round about the 400 mark without boost.
Sat Oct 18, 2008 10:10 pm
by Greasedmonkey
LaMbErT* wrote:you see im looking round about the 400 mark without boost.
Not gonna happen on any B series. Even hard on a K series. most ive seen on those is 300.
Sun Oct 19, 2008 11:56 am
by LaMbErT*
ah well looks like its boost then
Sun Oct 19, 2008 7:09 pm
by Greasedmonkey
You knew you were going boost the whole time if you wanted 400 hp.
Sun Oct 19, 2008 7:19 pm
by Faded_Milano
boost, or four more cylinders
Sun Oct 19, 2008 9:39 pm
by bietelboer
Faded_Milano wrote:boost, or four more cylinders
Haha indeed
Tue Oct 21, 2008 5:40 pm
by LaMbErT*
I really wasn't wanting to turbo it tbh
Wed Oct 22, 2008 12:10 am
by Greasedmonkey
then you need to lower your power goals. 200 whp is alot for a civic.
Wed Oct 22, 2008 2:13 am
by Faded_Milano
LowtecDerbo had 272 whp and 214 wtq with a built turbo D. So the 300's with a built turboed B18c is possible, just expensive.
Wed Oct 22, 2008 6:13 am
by B-eg
He wanna keep it NA
Wed Oct 22, 2008 6:37 am
by LowTEC-Derbo
the only way to even COME CLOSE is running a 2.4 liter K series block with HIGH HIGH Compression 14:1 (something undrivable on the streets) running on alcohol.
You would probably be idling at 3000rpm with a rough idle and probably spin to 10k-11k rpms to even come close to 400. You will sacrafice longevity of the motor just by making it so powerful.
250whp from a B series is more than enough to reach 12s in a hatch. Its actually possible to hit 11s with that kind of NA power.
Mind you, turbo hp is alot different than NA hp. alot of 200whp NA guys keep up with my old turbo setup till we hit around 80+
