- Wed Oct 15, 2008 2:12 pm
#74397
k so i just did a compression test on my jdm B16A and got these readings. cycl1 180 cycl2 175 cycl3 175 cycl4 180. i am curiuos if i did the test correctly though. i pulled all the sprakplugs, fuel injector clips, and the fuel pump fuse, then put the tester in the plug hole, finally i cranked the car over till the compression tester needle moved 5 movements. is thats correct and do those reading seem right?
P.S. the car was cold when the test was done.
