B16, B18, B20
By Josiah
#72671 stock motor supports from d16 dont work... do i use the b18 or what? the side and back are ok but were talking about the two in front off the tranny and motor on the lower half
#72676 Mounts from a 94-01 Integra will work, Also will need 94-01 Integra shift linkage and axles.
By x-racer
#72908 we just did a b20 swap into my bud's eg hatch.
we used the side motor mounts from the single and the rear mount from the teg.this thing is quick.
By Josiah
#72990 the two mounts that bolt to the flimsy U shaped mounts in the front on the bottom dont line up. my minime ones dont line up with the bolts. does anyone have any for sale, is there a trick to it, like the vtec wiring and radiator fan wiring that no1 knows about?
By JDM FERIO MAN
#72994 get all of them from a gsr teg and you will be good 8)
By Josiah
#73008 nevermind
