B16a In CRX Si
PostPosted: Fri Jul 25, 2008 3:24 am
by Dippin_EG
This question is a little off topic, but i am yet to find a definite answer. I am swapping a JDM b16a into a CRX Si (91), and i need to know if i am to use the fuel rail and injectors, clips and distributor drom the D16 i took out of it. The OBD0 D15 Injector clips dont fit on the B16 and i have heard to use the Si's stuff but never got a definite answer. Any help would be much appreciated
PostPosted: Fri Jul 25, 2008 6:30 am
by Benj
you have to use the si clips and harness, you sould also use the b16 injectors, for flow. now i have heard a few people say that all honda injectors are the same but i am not sure, i also know that you have to use the ecu for that enine to run vtec, so you have to go on ebay and buy a jumper harness or build one and then you also have to pin ( wire) in the vtec solenoid, question for you what the motor out of???
PostPosted: Sun Jul 27, 2008 4:35 pm
by Dippin_EG
Problem solved.... so far
