- Wed Jun 18, 2008 2:01 pm
#58978
Well ive actually decided thanks to people over at d-series.org to go with a ls swap since its going to be cheaper than the building up of a Z6 and in the end be more powerful....
Ive already hunted down a couple of cable transmitions and am going to go out and buy a hydro to cable conversion for around 150ish and am probaly going to get my friends Bseries motor from his teg for doing a stock ls swap back into his car.....
What I am wondering is will there be any problems with me running the b20 head on the ls block I know hes had some problems with it not giving up what it should in the power dept. he thinks it could be the head gasket was setup wrong or something by the previous owner.....
What I am truely wondering is what head gasket kit should i get for that motor?, what is the point of this head being on the ls block i know on the sohc motors you put a Y8 head on a Z6 block and you get higher compression is this the same thing?
I plan on probaly replacing all the gaskets getting the motor torn all down for the most part getting the head straightened as a precaution that is....and cleaning up everything who knows might even swap the rods and pistons if i have enough in my budget which right now is non exhistent but slowly growing. What would be the best way to clean up the motor and should I just for precaustionary measure replace the rods and pistons or if I inspect them and they look to be fine then should i just keep them in there and maybe clean the carbon off of them ???
Thank you
Thank you
1980 volvo 242
2001 crv
2001 crv
