- Sun Jun 15, 2008 5:54 am
#58570
I don't think my vtec is kicking in would that have anything to do with my speed sensor? Because my speedometer is not working.
- Sun Jun 15, 2008 10:32 pm
#58646
I have done some other research and found out it is the vss. I also found out that the b16a has an electric vss, does this mean I need a different gauge cluster? Can anybody please help I want my vtec to work.
- Sun Jun 15, 2008 10:53 pm
#58648
Yes the vss
- Thu Jun 26, 2008 7:11 pm
#59885
clustdoesnt matter, replace the vss or straight wire it.
- Fri Jun 27, 2008 3:47 pm
#59967
yes. It shoulcn't have anything to do with vtec. vtec functions on oil pressure.
Ecc0 wrote:I thought that the vss was attached to the gear box and not to the clocks if so it will be easily replaceble.
- Fri Jun 27, 2008 8:04 pm
#59993
Thought as much in that case take your Vtec soleniod off and clean the wire mesh filter its common for them to get clogged up if that doesn't work see if you can borrow a friends soleniod and see if it'll run it then.
It looks like the VSS is a seperate problem though so should try and deal with that too.
teal_dx wrote:Ecc0 wrote:I thought that the vss was attached to the gear box and not to the clocks if so it will be easily replaceble.
- Thu Jul 03, 2008 2:13 am
#60550
I fixed the problem. I rechecked all the wires from the vss and the guy that did my swap crossed up the ecu wire an the ground wire on the vss. Now my vtec works great.
- Thu Jul 31, 2008 10:02 am
#64103
Good deal man
My sig was too large, I need to read the Rules & Guidelines
