starting issues
PostPosted: Wed Feb 20, 2013 8:31 pm
by madhatchride
Help....ive just swapped a b18b into my 94 coupe im running a stock p28 ecu and the factory d16 z6 wiring harness just yesterday i dry started it with no distributor turned over no problem.well today i got my obd1 to ,obd2 dizzy plug from rywire. When i go to start my car it clicks like 3 times like it had a bad connection on the battery.well the final tine i go tohit the starter the fuel pump would no kick on and instead of the starter engaging the radiator fan engages im lose can someone plz help
PostPosted: Wed Feb 20, 2013 11:36 pm
by bks84
Is your battery dead?
Check all your connections... both batt connections, grounds etc
PostPosted: Thu Feb 21, 2013 1:35 pm
by madhatchride
It was tbe ground on the transmission side
