b16a, itr, ctr drivers help
ok so i trying to figure something out. i read online that the itr, ctr, and b16a share the same heads and that they are stamped pr3 can anyone confirm this. i know the difference from the itr, ctr from the b16a is a hand port job from honda.
now the other problem is trying to figure out the combustion chamber ratio on all 3 motors. if they all have the same cylinderhead then why is it that the ctr has a lower compression then the itr.
for an example
ctr pistons in a b16a will yeild 11.1 ish. but ctr piston in a b16b has a 10.8
it should be the same if i put ctr pistons in my b16a if they got the same heads also usdm itr pistons in a b16a will yeild 10.4 ish but they got a lower dome then the p30 b16a pistons.
the usdm b16a pr3 has a compression of 10.2
jdm b16a p30 has 10.4
usdm itr p73-a0 has 10.6
jdm itr p73-00 has 11.1
ctr pct has 10.8
usdm 99-00 or jdm 88-91 b16a piston
jdm b16a piston
usdm itr piston
jdm itr piston
ctr piston
for an example
ctr pct has 10.8
jdm b16a piston
usdm itr piston
jdm itr piston
ctr piston
