- Sat Aug 18, 2007 5:34 pm
#20331
I'm thinking about buying an oil-thirsty B16A2 longblock, for cheap.
It needs some work, it'll take time, it hurts my gut but I'm patient
I really want to go low boost (up to 10psi) on it eventually, so I guess I'm 'stuck' with the original c/r.
Are there any pistons available, that provide me with the same amount of compression, but are stronger than OEM pistons?
All I've seen are low or high compression pistons, wich both are no option.
Also been thinking of new rods, but if they're not needed for low boost, I wont buy them, what's your 2cts ?
Since I want to boost after a while of n/a driving, I was thinking of buying a Skunk2 i/m with a 68mm throttlebody, but would this be overkill on a B16 with only some bolt-ons like an egay header and a WAI?
Also, I want to run 450cc injectors, so I don't like buying the OEM injectors first, and then the 450's.
Can I run the car without boost with 450cc's, or are they just to big to tune to a proper a/f ratio or get the car running smoothly?
About the headgasket, is it wise to use an original Honda one, or is it better to upgrade to something else...
This also goes for the headstuds -> replace them with ARP, or keep the OEM ones?
The head is good, but I'll be replacing the valve seals, so no work on that (just cleaning, and maybe some portmatching).
