Help plz b18a
for the past 3 months i have been working on a 93 ls swap into a 92 dx hatch.
I got the car as a shell and with not a thing in it. so i got a 94 dx harness for it. as of right now this is my set up. 93 ls motor,ls trans, obd2 ls intake manifold,94 ls tb, the ecu is a pc4 out of a 93 da 5 speed. seems like it all work right? lol
the car is almost done and this is the last prob i am having. cel code 3 and cel code 14 map sensor and iac.
now i test my iac plug and its not getting any power to it at all at 1st i thought it was the plug so i went to the ecu and tested the iac wire at the back of the 26 pin plug. still nothing no power is coming out at all and it is making the car idle really woopy. also i tried to direct conect it to the batery like running a wire from the postive to the positive on the iac and still nonthing lol
also i have tried a diffrent ecu thinking it was that and still nothing. does any one have any ideas plz help if you can thank so much
