b20b does not pass 3000rpm and has idle.
Thu Dec 17, 2009 9:02 pm
by EGR95
i have a b20b in my 95 honda civic. the problem is that my engine does not rev pass 3000rmp. i spoke to a mech and said that it could be etheir my MAP or TPS. now i know some b20b have a crank sensor for the obd2 modle, but my engine not have it, could that be the problem as well? has a rough idle.
mods: my b20b has a b16a intake mainfold and it has a GSR aftermarket throttle bodie with the b20b MAP sensor and TPS, and the idle air control valve. And i have a po5 obd1 chip Ecu for the b20b and gsr injectors.
Thu Dec 17, 2009 9:22 pm
by Classiccarsrule85
it may be the gsr injectors harming power but theres also definately most liekly its your tps sensor im going right after that because your running on a obd1 ecu which makes the crnk position sensor obsolite....so its most likely your tps but can also be your map....and the rough idle dose tell me that it can be a tps since it dosent know the throttle position or is not reading it correctly...
Thu Dec 17, 2009 11:26 pm
by EGR95
Classiccarsrule85 wrote:it may be the gsr injectors harming power but theres also definately most liekly its your tps sensor im going right after that because your running on a obd1 ecu which makes the crnk position sensor obsolite....so its most likely your tps but can also be your map....and the rough idle dose tell me that it can be a tps since it dosent know the throttle position or is not reading it correctly...
true, but today what i did is i grab my chip ECU and install it in my friends hatch, and it did the same thing it would idle and it would not rev pass 3000 RPMS so i think its the computer. im going to get a LS computer obd1 computer.
but a friend told me to take out the j1 out of the ECU to see if it changes.
Fri Dec 18, 2009 12:10 am
well if it did that to his most liely it is the culprate chipped ecus are good but yea depends on who installs what tune etc...
Fri Dec 18, 2009 3:53 am
by chrono404
what head is on that engine? a stock b20 head is the same as a ls head with different cams. That head wont accept a b16 intake manifold.
If you cant rev over 3k i would say its probally an ecu issue. It could be an issue with 2 step not working working , most of the time thats set around 3k.
Fri Dec 18, 2009 4:31 am
by EGR95
Classiccarsrule85 wrote:well if it did that to his most liely it is the culprate chipped ecus are good but yea depends on who installs what tune etc...
well im just going to get a ls computer... what do you say?
Fri Dec 18, 2009 4:34 am
by EGR95
chrono404 wrote:what head is on that engine? a stock b20 head is the same as a ls head with different cams. That head wont accept a b16 intake manifold.
the head on the engine is the stock b20b. the b20b and the b18b have different port size. my b20b did accept a b16a intake manifold ( with some mods) i can take some pics if you like.
