- Fri Oct 15, 2010 10:39 pm
#218500
if i was to get a jdm itr block would it make more power than a itr block with itr head
#218501
i have a b16b by the way
- Fri Oct 15, 2010 10:47 pm
#218502
B16B and ITR heads are the same casting. Only difference is the ITR head was hand ported a little bit from the factory. Not a whole lot, but still.
IDK what the differences are between the B16B and ITR cams. But I would expect similar power output between a B16B head on JDM ITR block and a full on JDM ITR.
- Sat Oct 16, 2010 12:26 am
#218520
so if i have the itr block i will be pushin the same as and itr or what would be the power gains goin from full b16b to itr block
- Sat Oct 16, 2010 12:55 am
#218524
I don't think you would see much different with an ITR compared to a B16B. If anything I think the b16 would win. Higher compression andbyou can spin it to 10k stock if you want. A b16b is a factory motor but even stock it is a race motor which is why everybody wants the cams and pistons.
"If you want your car to be cheap and fast it wont be reliable... If you want your car to be reliable and cheap it wont be fast... If you want your car to be fast and reliable it wont be cheap"
- Sat Oct 16, 2010 1:02 am
#218525
Difference in B16b/JDM ITR is 11HP and 9lbs of Torque. You would make more power by spending the money on Cams and tuning then getting a b18c Spec R Block.
If you want to get the B18c-R Bottom end with out paying the extra Type-R Tax you can get a B18c(GSR) Crank, Rods and JDM ITR Pistons(or better aftermarket ones) and still keep the B16B Badging on the block.
If it was me, I would person do Cams and an awesome Tune Job. B16's like to Rev, Its Type-R Edition is no Exception. Get Cams that make power upto 9-10k RPM and rev all day long.
jb-b16b-ej1 wrote:so if i have the itr block i will be pushin the same as and itr or what would be the power gains goin from full b16b to itr block
- Sat Oct 16, 2010 2:10 am
#218538
if you look at the pistons of the ctr vs. the itr, the ctr has better pistons than the itr and i think im not for sure but i think the ctr has a higher lift on the cam then the itr.
your car is your story, dont let someone else write the book.
91 s10 (sold)
92 civic si with jdm b16a (Sold) http://civic-eg.com/viewtopic.php?t=13460
99 civic lx (current) viewtopic.php?f=63&t=30348
91 s10 (sold)
- Sat Oct 16, 2010 2:14 pm
#218566
i was just tryin to get the torque numbers that the itr has cause my b16b always takes a while revin from 4-6.5 grand.
would i get the 1.8 displacement switchin crank rod and pistons out
- Sat Oct 16, 2010 2:21 pm
#218567
where would i find gsr rods and crank and itr pistons online
- Sat Oct 16, 2010 4:37 pm
#218577
B18 rods/crank wont work in the b16 block...
jb-b16b-ej1 wrote:where would i find gsr rods and crank and itr pistons online
- Sat Oct 16, 2010 5:14 pm
#218581
true for a b16a, the b16B is a destroked b18c-R and they will work in it.
JUICE wrote:jb-b16b-ej1 wrote:where would i find gsr rods and crank and itr pistons online
- Sat Oct 16, 2010 6:27 pm
#218587
thats what i was thinkin the deck heidth was the same on b16b and b18c
- Sat Oct 16, 2010 10:25 pm
#218606
yea the itr and ctr share the same deck hight. i was going to make a poor mans ctr out of a b16a but i found out you cant. anyways you should be able to put in the gsr crank and rods, imo i would say with the ctr pistons and run a b16a head so you can have the 11:1 compression ratio
91 s10 (sold)
91 s10 (sold)
- Sun Oct 17, 2010 2:40 pm
#218663
whats the difference in the b16b and b16a other than cams
- Sun Oct 17, 2010 3:36 pm
#218671
pistons, i think the intake manifold, block, and maybe even the head but im not for sure
91 s10 (sold)
91 s10 (sold)
