- Fri Oct 10, 2008 7:57 am
#73611
Hi Guys,
Quite new here, been following the forum on several topics and got lot of help as well. Was searching the forum and couldnt find what i was looking for, so i thought i will post.
I have a track prepared S2000, which is for road use also, quite happy with that and well versed also.
I recently purchased an EG with DC2 swap from a friend, amazing car and in good runing condition. i stripped it completely, roll cage and all FIA approved safety stuff installed to compete in local touring car championship. Car was fine when i purchased, we had removed some stuff from the engine compartment and installed back in.
I took the car for testing and having the following main problem:
1 - The car suddenly starts stalling or feels like no fuel suddenly, sometimes it happens on the corners (but the fuel level is still high) even when i let off the throttle, the fuel gauge comes on half tank position, the car is still doing same, it suddenly works and suddenly stops (fuel or elecrtical) i dont know. Really need your help on this.
The mods i have on the car:
- B18C - Type R 98 spec complete swap
- Spoon ECU
- MSD ignition
- Spoon Spark Plug Wires
- HKS Spark Plugs
- Walbro Fuel Pump - Higher Capacity
- Thinner HeadGasket
- Spoon Headers - B Pipe -Exhaust System
- J's intake (Had the AEM, removed it)
- J's Racing Throttle Body (Had Spoon, removed it, might put it back)
There are lot more mods on the car which are to do with body and suspension, i can give you the spec for those as well, if required, but i think this problem is not related to those.
Can you guys tell me what are the possibilities? List all possible ones and i can get those checked, i thought:
- Fuel Tank Baffle or install Surge Tank? But no one else is having same problem? A friend has same car with K20 swap without issues, using same tank as mine.
- Something wrong with spark plug wires from Spoon? :s ... but then why does it run initially and it starts doing it after 1 minute of track driving and then suddenly it starts runing again after 1 minute and then again.
- MSD?
- Fuel Lines?
Thanks alot in advance for any help
.. .quite desperate to sort it out cos racing start quite soon.
- Spoon ECU
- MSD ignition
- HKS Spark Plugs
- MSD?
- Fuel Lines?
