- Mon Feb 28, 2011 9:45 pm
#241502
what ECU? sounds like it's chipped.
most common for Vtec swaps is a chipped P28
- Thu Mar 03, 2011 3:04 am
#241908
Definitely been chipped if the crossover is at 6200rpm. Stock P72 crossover is at 4400rpm.
Hi, I'm John. I'm a hacky sackin', rock climbin', scuba divin', aircraft mechanic.
- Sat Mar 05, 2011 7:32 pm
#242427
[quote="JUICE"]^^ you get it re-tuned
[/quot
Def re tune with out knowing for sure what it is...... 6200 is a rather high crossover point.... I've heard that valvetrain damage can caused by higher crossover points unless it was what the cams were intended for like a 3/4 race cam or something like that......... its never easy on the parts to work at nd engage that higher speeds like that
[/quot
PANDA CREW No.20
PANDA CREW No.20
- Sat Mar 05, 2011 8:49 pm
#242441
i've always heard LOWERING the crossover point was bad for STOCK valvetrains.. not saying raising it is any better/worse for it cause i really dont know, just usually seems people want that Vtak sooner and they end up causing problems
forcefedEG wrote:JUICE wrote:^^ you get it re-tuned
- Sun Mar 06, 2011 12:13 am
#242473
ya im just swapping my pr3-j01 into it asap i dont even take it into vtec cause i dont like how high the crossover is so probelm solved
hey anyone want to buy a chipped p72 lol!!!
or maybe i will open her up and see what i can see just incase there is a reason for it being that way but with the way it runs now its highly unlikely
