running badly and air from valve cover
ok so my sis bought a 94 cx hatch she was told it needed a tune up....so i replaced plugs wires cap and rotor and its still running rough. noticed the valve cover was leaking so replaced the gasket too and found that it was missing one of the gromets that go under the nuts to hold the valve cover on so replaced it to...cars still running rough and if you hold your hand over were the valve cover meets the head in the back u can feel air coming out
so im guessin that shes getting some pressure built up in the crankcase now im wondering if there is anyways to test the pcv system i pull the valve off and it does rattle
any other sugestions on things it could be or things to try
it does idle rough and when you drive it, it feels gutless unless you rev it up like crazy before you shift then it feels like it all of a sudden gets a kick in power and takes off once its warmed up at lights it feels like its going to die...hasnt stalled yet but sure feels like its going to it almost does then comes back from it and then almost dies then comes back ...so on and so forth untill you start to go again
the car does smoke a lil bit but not all the time usually only it u rev the crap out of it
so any ideas on things to try or things it could be?
